Старый 20.05.2010, 20:06   #1
emeadaxsupport: When an expense line is rejected the remaining lines cannot be approved
Источник: http://blogs.msdn.com/emeadaxsupport...-approved.aspx
In AX2009, we have workflow approvals for expenses. When using the line item type approval with expenses you may notice that when one line in an expense report is rejected the remaining lines no longer appear for approval until the whole expense report is re-submitted.
Now this behaviour may not be to everyone's liking - I have come across customers which would prefer that when an expense line is rejected the remaining lines should carry on being approved regardless. It is actually quite simple to achieve this with a small X++ change. But first we should understand what is actually happening here: basically when an expense line is rejected we also set the expense header to rejected, and the header status is what prevents the remaining lines from being processed. So if we prevent the header being set to rejected when a single line is rejected then we can achieve the desired behaviour.
So to make the change: in the workflow expenses event handler class, Classes\TrvWorkflowElemEventHandler.returned(), remove the following lines:
if(TrvParameters::find().ApprovalLevel == TrvApprovalLevel::LineItem)
select firstonly ExpNumber from trvExpTrans where trvExpTrans.RecId == workflowContext.parmRecId();
TrvStateChangeManager::setDocumentStatus(trvExpTrans.ExpNumber, TrvAppStatus::Returned);
If you decide to use this, please make sure that you test it before use in any live environment, this code is given as an example only.
Shekhar: Dynamics AX,AX2009 – Credit remaining quantity Blog bot DAX Blogs 0 30.03.2010 15:05
palleagermark: It is possible for users to edit the Item reference fields of sales order lines and purchase order lines. Blog bot DAX Blogs 0 17.02.2010 21:07
dynamic-ax.co.uk: Dynamics AX: Counting Lines of Code – Mohammed Rasheed Blog bot DAX Blogs 1 03.07.2009 13:46
axaptafreak: Copying one line of a grid to Excel Blog bot DAX Blogs 0 17.01.2008 15:40
Часовой пояс GMT +3, время: 13:12.
