Старый 20.05.2010, 00:05   #1
axaptapedia: Call-back methods
Источник: http://www.axaptapedia.com/Call-back_methods
Summary: New page: ==Call-back methods== Sometimes it is useful to call methods on the parent/caller of your class. If you are using the runbase framework you can call accessors methods from the form that c...
If you are using the runbase framework you can call accessors methods from the form that called your run method to initialize a new object.
public static void main(Args _args)
    str callerName;
    if(_args.caller() != null)
        callerName = _args.caller().name();
        if(_args.dataset() == tableNum(BankAccountTrans) &&
            formHasMethod(_args.caller(), identifierStr(bankAccountStatement)))//check the form for an accessor method for the statement
            statement = _args.caller().bankAccountStatement();//get the bankStatment from the accessor method
            engine = new BankRecEngine(_args,_args.record(), statement.AccountId);//create a new runbase, fill params from the form calling this runbase
            if(engine.prompt())//ask the user for information
                engine.run();
axaptapedia: Accessor Methods Generator Blog bot DAX Blogs 0 05.03.2010 17:05
Dynamic Methods Microsoft CRM: Setting Notes back to Auto Expand Blog bot Dynamics CRM: Blogs 0 13.08.2009 15:05
SysDictCoder: X++ method call performance Blog bot DAX Blogs 1 04.05.2009 22:13
axaptapedia: Table Methods Generator Blog bot DAX Blogs 0 13.02.2009 02:05
AIFFault class AX2009 get all errors back in webservice call axstart DAX in English 0 28.01.2009 19:02
Часовой пояс GMT +3, время: 01:17.
