Старый 12.05.2010, 01:05   #1
emeadaxsupport: After applying PSA hotfix problem with using “Manage Expenses” from Enterprise Portal
Источник: http://blogs.msdn.com/emeadaxsupport...se-portal.aspx
Lately we run into problem that after applying PSA hotfix in this case (PSA_HF_2009SP1_046) after creating a new expense report the page was blank, but expense report was still created. It happen that mentioned hotfix modifies AOT \ Web \ Web Files \ Static Files \ Proxies.
The hotfix add following lines:
/class:PSAProjBudgetTolerance
    /method:PSAProjBudgetTolerance.checkBudgetTolerance
What would mean that in \wwwroot\wss\VirtualDirectories\
emeadaxsupport: HTTP 401 Error when trying to deploy/create an Enterprise Portal site on a load balanced farm using a hardware load balancer Blog bot DAX Blogs 0 06.05.2010 03:16
emeadaxsupport: How to manually deploy ODC Files to Microsoft Dynamics AX 2009 Enterprise Portal Blog bot DAX Blogs 0 17.02.2010 21:07
emeadaxsupport: The mystery of blank Enterprise Portal pages Blog bot DAX Blogs 0 28.07.2009 16:05
emeadaxsupport: AxUpdatePortal.exe does not update Enterprise Portal when not running from an elevated command prompt Blog bot DAX Blogs 0 26.07.2009 15:07
Часовой пояс GMT +3, время: 21:01.
