Старый 08.04.2010, 15:05   #1
axaptapedia: SourceCodeToHTMLPrinter
Источник: http://www.axaptapedia.com/SourceCodeToHTMLPrinter
Summary: Allows X++ Source Code to be converted and placed in the HTML Viewer where it can then be printed
This is for those developers whom from time to time print their X++ source code to a printer.
The standard functionality only prints in black and white. This small Module will allow you to print in color and will give the same look and feel as the CodeEditor.
[[Image:SourceCodeToHTMLPrinter.jpg]]
[[Media:SharedProject SourceCodeToHTMLPrinter.zip]]
This Project has been developed for Microsoft Dynamics AX 2009
After the XPO SourceCodeToHTMLPrinter has been imported, the Method addIns_PrintCode should be inserted in the standard Class EditorScripts.
The Method may be found in the Class SourceToHTML_Converter.
axaptapedia: Tutorial Password Blog bot DAX Blogs 1 22.05.2009 21:23
axcoder: PowerShell + Ax Blog bot DAX Blogs 1 09.01.2009 18:05
axaptapedia: Load Web Documents Blog bot DAX Blogs 1 03.01.2009 23:50
axcoder: AxPath is supported by axaptapedia Blog bot DAX Blogs 0 11.05.2007 10:00
Часовой пояс GMT +3, время: 17:33.
