Старый 22.03.2010, 22:01   #1
Vadik is offline
Vadik
Аватар для Vadik
3,631 / 1853 (69) ++++++++
Microsoft Dynamics AX 2009 White Paper: Planning Database Configuration
Brief Description
The configuration checklist in this document will help you configure the Microsoft Dynamics AX database for optimal performance.
-ТСЯ или -ТЬСЯ ?
Старый 09.04.2010, 11:53   #2
Poleax is offline
Poleax
Аватар для Poleax
1,353 / 595 (22) +++++++
Записей в блоге: 34
Thumbs up
Brief Description
Занятный мануал
Disable hyperthreading. Microsoft Dynamics AX has not been extensively tested with hyperthreading and we recommend that you disable it. For instructions, refer to the hardware documentation for your server as this step must be performed in the BIOS settings of the server.
Жаль тему закрыли http://www.sql.ru/forum/actualthread...d=650982&pg=18
Последний раз редактировалось Poleax; 09.04.2010 в 12:04.
ax2009, sql server, документация, скачать (download)
emeadaxsupport: Checking Database entries after restoring a Microsoft Dynamics 2009 SQL Database to another Domain or Environment Blog bot DAX Blogs 0 18.02.2010 23:05
Microsoft Dynamics AX 2009 White Paper: Application Integration Framework (AIF) BizTalk Adapter Configuration for Data Exchange, Part II - English Vadik DAX: База знаний и проекты 0 14.04.2009 09:36
Часовой пояс GMT +3, время: 18:49.
