#1 |
emeadaxsupport: You get a warning message when deploying the AX 2009 smmOpportunityReports report library
Источник: http://blogs.msdn.com/emeadaxsupport...t-library.aspx
============== When deploying the AX 2009 smmOpportunityReports using the Reports Deployment tool or directly from the AOT, you may get the following warning: One or more libraries built with warnings. Please see MSBuild log at C:\Users\\AppData\Local\Temp\1\tmp98ED.tmp Deploying 1 data source(s) and 2 design(s) in 3 culture(s) (7 item(s) total)... Deployment done at 13:25:38. Duration: 00:00:23.5803347 The deployment log file can be found at "C:\Users\\AppData\Local\Temp\1\tmp1319.txt" (Note: any random tmp filename will be generated). Checking the .tmp file that is specified in the warning in notepad reveals the following warning: … … Target CoreCompile: C:\Users\\AppData\Local\Temp\1\tmp1329.tmp\smmOpportunityReports\smmPipelineMonthOverMonthClosingTrend.moxl : warning AX3020: The data method 'GetColor' in class 'smmPipelineMonthOverMonthClosingTrend' is not present in the model. Done building target "CoreCompile" in project "smmOpportunityReports.dynamicsproj". … … Done building project "smmOpportunityReports.dynamicsproj". Build succeeded. C:\Users\\AppData\Local\Temp\1\tmp1329.tmp\smmOpportunityReports\smmPipelineMonthOverMonthClosingTrend.moxl : warning AX3020: The data method 'GetColor' in class 'smmPipelineMonthOverMonthClosingTrend' is not present in the model. 1 Warning(s) 0 Error(s) You can safely ignore this warning. There is a code fragment left behind in the smmPipelineMonthOverMonthClosingTrend.cs file which declares a GetColor() method but it is actually not exposed or used in the report library model. Источник: http://blogs.msdn.com/emeadaxsupport...t-library.aspx
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
