Старый 15.01.2010, 02:09   #1
lcash: Hyper-V VM starts going to “Paused-Critical” status
Источник: http://blogs.msdn.com/lcash/archive/...al-status.aspx
As folks are starting to move to use Hyper-V there will be some new messages and things that you will pick up. I got an email from Toni in Spain that suddenly the VM is showing as “Paused-Critical” status in the Hyper-V manager.
Ordinarily the VM should run happily and the status is “Running”
But I’ve had this as well, if over time, the disk space is used on the machine that you are running on then Hyper-V will stop the VM to avoid damage. So it will pause the machine. So if you see you VM being stopped then you might want to check the disk space you have and make sure that you have at least enough space equal to the amount of memory you are assigning the VMs you have running on the machine.
Cheers
Lachlan
Original post at http://blogs.msdn.com/lcash
lcash: Additional disks with Refresh 2 and creating your own VMC or VM configuration Blog bot DAX Blogs 0 19.10.2009 17:05
lcash: unzipping the VM files, external disks not formatted for NTFS Blog bot DAX Blogs 0 04.09.2009 14:05
lcash: Moving the AX App and DB onto a new VM Blog bot DAX Blogs 0 29.07.2009 12:05
lcash: Using document handling to add image in Demo VM Blog bot DAX Blogs 0 21.07.2009 10:05
Часовой пояс GMT +3, время: 02:21.
