Старый 08.01.2010, 16:05   #1
paruvella: Dynamics Ax - Simple SSRS report example by using Ax-Query and Ranges
Источник: http://paruvella.spaces.live.com/Blo...4DB0!408.entry
In this report I am going to use the Ax-Query in the SSRS business logic and report will be generated by using SSRS Business logic.
For this report…
1)      Define the sample Ax Query in Dynamics Ax as follows...
2)      In the above SampleCustomers query I had defined the ranges for the Name Field.
3)      Now go to VS-2008 Create New Project for Dynamics Ax SSRS reports.
4)      Open the report from the Solution explorer and Add the new DataMethod to the report as follows
 5)      Rename the DataMethod and do the code as follows
    [DataMethod(), AxSessionPermission(SecurityAction.Assert)]
    public static DataTable CustomerDetails(String custAccName)
        DataTable custDataTable = new DataTable();
<span style="font-size:10pt;font-family:'Courier New'">        IDictionary<span style="color:blue"string/span, span style="color:blue"object/span> ranges = new Dictionary();
        DataRow customersRow;
        DataTable dtASCAllRows = new DataTable("Customers");
        DataView dvASC = new DataView();
        //Defining ranges
        object[] rangeName = new object[] { "CustTable.Name" };
        object[] rangeValue = new object[] { custAccName };
        ranges.Add(rangeName[0].ToString(), rangeValue[0]);
        // execute query - "SampleCustomers" is our Ax Query
        dtASCAllRows = AxQuery.ExecuteQuery((String.Format("Select * from {0}", "SampleCustomers"))
            , ranges);
        dvASC.Table = dtASCAllRows;
        custDataTable.Columns.Add("AccountNum", typeof(string));
        custDataTable.Columns.Add("AccountName", typeof(string));
        custDataTable.Columns.Add("CustGroup", typeof(string));
        // Loop for fetching data for every record
        for (int intLoopCounter = 0;
            intLoopCounter < dvASC.Count; intLoopCounter++)
            customersRow = custDataTable.NewRow();
            customersRow["AccountNum"] = Convert.ToString(dvASC[intLoopCounter]["AccountNum"]);
            customersRow["AccountName"] = Convert.ToString(dvASC[intLoopCounter]["Name"]);
            customersRow["CustGroup"] = Convert.ToString(dvASC[intLoopCounter]["CustGroup"]);
            custDataTable.Rows.Add(customersRow);
        return custDataTable;
6)      Define the new Dataset for the report.
       7)      Assign the properties of the dataset as follows and Map our DataMethod (CustomerDetails) to the Query Property of the DataSet.
8)      Save the solution. Drag and drop the Dataset to the Designs node of the report.
9)      Now we can see the report preview of the report by using the Customer name as filter condition.
Проблема при создании нового Query в Report (AX 2009) Galyna DAX: Программирование 1 21.12.2009 01:56
Dynamics AX Geek: Using query() Blog bot DAX Blogs 0 04.05.2009 14:05
axStart: Please keep the AOT reports in Dynamics AX next release alive Blog bot DAX Blogs 2 13.12.2008 12:18
axStart: Getting Dynamics AX information into Dynamics CRM, the easy way. Blog bot DAX Blogs 0 15.07.2008 02:13
Dynamics AX Geek: Using query() Blog bot DAX Blogs 0 28.10.2006 16:40
Часовой пояс GMT +3, время: 06:28.
