Старый 31.10.2009, 06:25   #1
Dianne Siebold: AX SDK on MSDN Now Wiki-ized
Источник: http://blogs.msdn.com/dsiebold/archi...wiki-ized.aspx
If you're an AX developer, I have some good news: the Dynamics AX 2009 developer documentation on MSDN is now enabled for community content (aka wiki). So now you can post comments, code samples, bug reports, kudos and brickbats on any particular topic.
You’ve most likely seen the wiki in action on MSDN if you’ve ever browsed the help for .NET or SQL Server or any of the other developer products. Just scroll to the bottom of any topic and you’ll see the Community Content pane. Click the Add new content link to sign in and start talking. You will need to have a valid Live ID to sign in and post a comment. Currently, only the AX 2009 help is wiki enabled, but we plan to enable this feature on the AX 4.0 help soon.
Let the discussions commence!
Dianne Siebold: AX 2009 SDK Updates on MSDN Blog bot DAX Blogs 0 16.05.2009 11:05
Dianne Siebold: Update to the Microsoft Dynamics AX 4.01 SDK Now Released Blog bot DAX Blogs 1 18.08.2008 15:28
Dianne Siebold: Microsoft Dynamics AX 2009 SDK Now Online Blog bot DAX Blogs 0 13.06.2008 12:05
Dianne Siebold: Limit MSDN Search to AX Content Only (4.0) Blog bot DAX Blogs 0 16.02.2008 04:41
Часовой пояс GMT +3, время: 07:29.
