Старый 26.10.2009, 14:05   #1
Kashperuk Ivan: Mock objects implementation for AX
Источник: http://kashperuk.blogspot.com/2009/1...on-for-ax.html
As you might now, I am working as a Software Development Engineer in Test at Microsoft Development Center in Denmark.
But the only real test framework that comes with AX is the SysTest framework (you can read more about it here).
Below you will find another framework for Dynamics AX, that was written by one of the members on my test team and allows to implement and use mock objects for testing the AX application.
More information and download link
It would be great if you could try it out and provide your feedback here or directly on the author's blog.
Kashperuk Ivan: Microsoft Dynamics AX 4.0 data model overview Blog bot DAX: База знаний и проекты 81 16.12.2013 15:25
Kashperuk Ivan: AxGoToDeclarationI haven't posted in a while. W... Blog bot DAX Blogs 2 07.06.2010 00:06
Kashperuk Ivan: Lookup methods tutorial + custom list lookup implementation Blog bot DAX Blogs 0 04.05.2009 14:05
Kashperuk Ivan: Dynamics AX Tutorials - Tutorial 2 - Classes\Box Blog bot DAX Blogs 0 25.04.2007 22:23
Kashperuk Ivan: AxCreateNewProject version 1.3.1 availableI have... Blog bot DAX Blogs 0 08.02.2007 22:31
Часовой пояс GMT +3, время: 12:38.
