Старый 02.09.2009, 16:05   #1
Everything AX: Using the .NET Business Connector from PowerShell
Источник: http://www.crankturner.com/2008/12/u...ctor-from.html
Ok, we've made the big jump to Dynamics AX 2009! Wow, lots of work going all of the way from Axapta 3.0
One of the hurdles was dealing with the COM connector. This is no small undertaking - the COM interface has CHANGED! It was time to upgrade to the .NET business connector. After installing the .NET client dll, we are now able to connect to our servers using the .NET Business Connector. Here is an example in PowerShell.
view plaincopy to clipboardprint?
  1. # load the .dll (similar to the c# "Using" statement)
  2. [reflection.Assembly]::Loadfile("C:\Program Files\Microsoft Dynamics AX\50\Client\Bin\Microsoft.Dynamics.BusinessConnectorNet.dll")   </span>
  3. $ax = new-object Microsoft.Dynamics.BusinessConnectorNet.Axapta
  4.
  5. # Look at the properties   </span>
  6. # More info at: http://msdn.microsoft.com/en-us/library/aa626373.aspx   </span>
  7. # $ax | get-member
  8.
  9. $ax.logon("","","","")   </span>
  10. $o = $ax.CallStaticClassMethod("SysLabel","labelId2String2","@SYS21669" )    </span>
  11. $o # Should be "ABC"  </span>
  12.
  13. # Look at some session info   </span>
  14. $xSession = $ax.CreateAxaptaObject("XSession")   </span>
  15. $xSession.call("AOSName")   </span>
  16.
  17. $xApplication = $ax.CreateAxaptaObject("XApplication")   </span>
  18. $xApplication.call("buildNo")   </span>
  19.
  20. $ax.CallStaticClassMethod("Session", "isBusinessConnector")     </span>
  21. $ax.CallStaticClassMethod("Session", "getAOSInstance")     </span>
  22. $ax.CallStaticClassMethod("Session", "getAOSPort")   </span>
  23.
  24. $ax.logoff()
Merry Christmas to all!
...Greg
@import url("http://greg.graham.googlepages.com/syntaxHighlighter.css");
Arijit Basu: DAX 4.01 .NET Business Connector: Microsoft.Dynamics.BusinessConnectorNet Blog bot DAX Blogs 3 30.09.2008 01:17
C# and AX Development: Using the .NET Business Connector for Dynamics AX / Axapta Blog bot DAX Blogs 0 18.12.2007 04:00
Inside Dynamics AX 4.0: Working with the .NET Business Connector Blog bot DAX Blogs 0 04.10.2007 05:15
ALEG: Проект "Фишка недели" и первый пост - Microsoft Dynamics™ AX .NET Business Connector Blog bot DAX Blogs 1 22.11.2006 09:43
Часовой пояс GMT +3, время: 22:06.
