Старый 12.08.2009, 05:15   #1
AX UK: Microsoft Dynamics AX 2009 Roll-up 2 Availability
Источник: http://blogs.msdn.com/ukax/archive/2...ilability.aspx
To assist our partners and customers in their new Microsoft Dynamics AX deployments, the SE team started releasing roll-ups for Microsoft Dynamics AX 2009 RTM and SP1 platforms. The roll-ups aim to provide an easy way of deploying Microsoft Dynamics AX with the latest hot fixes on a given Service Pack level. Roll-up 2 for Microsoft Dynamics AX 2009 RTM and SP1 has been available on PartnerSource and CustomerSource as of June 29th, 2009.
There will be one roll-up package for each Service Pack level. Each roll-up will carry all previously released hot fixes up to one month prior to the release of the roll-up and country specific updates. Each roll-up will be cumulative and will not require the presence of the previous roll-up on the system.
The roll-up package will contain both a cumulative kernel update and a cumulative application update. Although there is no dependency between these two updates, we recommend that you install both of the updates together. The roll-up will be installed on P-layers (i.e. SYP and GLP) and update the SYS layer as well as the GLS layer that is installed on the system.
· Dynamics AX 2009 RTM RU-2 KB Article à KB971535 (Download Package Size = 60MB)
· Dynamics AX 2009 SP1 RU-2 KB Article à KB971536 (Download Package Size = 80MB)
Posted By Fee Nolan
Dynamics AX Sustained Engineering: Microsoft Dynamics AX 2009 Roll-up 2 is available on Partner Source and Customer Source! Blog bot DAX Blogs 0 10.07.2009 10:05
Dynamics AX Sustained Engineering: Microsoft Dynamics AX 2009 Roll-up 1 is available on Partner Source and Customer Source! Blog bot DAX Blogs 0 15.04.2009 10:05
AX UK: Microsoft Dynamics AX 2009 Exam Deadline extended to 1st July 2009 Blog bot DAX Blogs 0 03.12.2008 19:05
Часовой пояс GMT +3, время: 03:48.
