Старый 29.07.2009, 05:07   #1
lcash: Syncing AX to Outlook on demo VMs
Источник: http://blogs.msdn.com/lcash/archive/...-demo-vms.aspx
I’ve had a few questions from partners on what this message means when you try to sync to Outlook from Dynamics AX.
Method 'add' in COM object of class '_Items' returned error code 0x80004004 () which means: .
Generally this is a result of Outlook not having access to the server. On the demo images this is usually a result of the services not being started. So you will need to make sure you have these two services started to send email.
  • Microsoft POP Service
  • Simple Mail Transfer Protocol (SMTP)
So click Start\Administration Tools\Services. Locate these services and start them.
This note on configuring the services on the demo VMs will help you understand which services do what. http://blogs.msdn.com/lcash/archive/...ax-srv-01.aspx
Cheers
Lachlan
Original post at http://blogs.msdn.com/lcash/
lcash: Setting up the Dynamics AX demo images in Hyper-V Blog bot DAX Blogs 0 29.07.2009 05:07
lcash: Setting up external networking on the Demo VMs Blog bot DAX Blogs 0 22.07.2009 09:05
lcash: Setting up Outlook Sync from Dynamics AX Blog bot DAX Blogs 0 21.07.2009 10:05
dynamic-ax.co.uk: Import Emails from Outlook 2007 into Dynamics AX 2009 Blog bot DAX Blogs 1 03.07.2009 07:17
Часовой пояс GMT +3, время: 21:15.
