Старый 21.04.2009, 04:07   #1
Solutions Monkey: AX Custom bound fields
Источник: http://blogs.msdn.com/solutions/arch...nd-fields.aspx
A new code sample demonstrating the flexibility to customize the boundfields in Microsoft Dynamics AX 2009 EP is released in http://code.msdn.microsoft.com/axcodesamples. Here is the link directly to the sample download file. To try out these samples, download this zip file and follow the instructions given in readme.txt file http://code.msdn.microsoft.com/Proje...ownloadId=5497
EP comes with a rich set of bound fields. This code sample demonstrates how to extend and add bound fields in EP for specific user interface requirements. This sample contains three types of bound fields:
  • Multi-line text
  • Day/month/year dropdown
  • Foreign key lookup that displays a description instead of an ID
Data binding provides an easy and powerful way to create a read/write link between controls on a Web page and the data in an application. With ASP.NET data binding, you can bind any server control to an AxDataSource control in EP and read and write data from Microsoft Dynamics AX seamlessly with little or no server code.
NOTE : These are code samples are not intended for production use as is. You should use them as samples and build your own solutions and test it before using it in production system. These sample bound fields do not work with BoundField designer in VS. You should work in the markup directly to use these boundfields or make the code deal with the boundfield designer.
Solutions Monkey: Microsoft Dynamics AX 2009 Enterprise Portal / Role Centers - Deployment Tips-n-Tricks – 3 Blog bot DAX Blogs 0 27.10.2008 08:05
Solutions Monkey: Disabling Bound Fields through code Blog bot DAX Blogs 0 16.10.2008 00:05
Solutions Monkey: Microsofty Dynamics AX 2009 Enterprise Portal / Role Centers - Deployment Tips-n-Tricks - 2 Blog bot DAX Blogs 0 30.09.2008 07:07
Solutions Monkey: Microsofty Dynamics AX 2009 Enterprise Portal / Role Centers - Deployment Tips-n-Tricks - 1 Blog bot DAX Blogs 0 26.06.2008 09:05
Solutions Monkey: Ax 4.0 Platform - a big leap forward... Blog bot DAX Blogs 0 03.10.2007 23:11
Часовой пояс GMT +3, время: 04:24.
