Старый 23.02.2009, 12:26   #1
Vadik is offline
Vadik
Аватар для Vadik
3,631 / 1853 (69) ++++++++
Kernel rollup 958213 for Microsoft Dynamics AX 4.0 SP2 is now available
Problems that are resolved in kernel rollup 958213
  • The enabled method on a form button control returns an incorrect value
  • Error message is in the Application log in Microsoft Dynamics AX 4.0 SP2: "The Microsoft Dynamics AX Application Object Server is running on an operating system that is not supported"
  • The alignment of a field in a report is lost if a long string continues onto the next page
  • AOS memory consumption occurs and AOS server may stop responding if you use Microsoft Dynamics AX 4.0 SP1
http://support.microsoft.com/hotfix/...958213&kbln=ru
-ТСЯ или -ТЬСЯ ?
За это сообщение автора поблагодарили: mazzy (2), glibs (1).
ax4.0, download, kernel rollup, rollup
Dynamics AX: Why Dynamics AX beats SAP Blog bot DAX Blogs 0 10.01.2007 23:15
Часовой пояс GMT +3, время: 11:41.
