#1 |
staticsax: Restore(ctrl-F5) and access control (AllowEdit) problem
Источник: http://staticsax.blogspot.com/2009/0...s-control.html
============== Trivia: It is usual programming pattern in AX that one overrides active() method on the datasource to allow/disallow data entry on fields depending on values of any fields in record. It is also usual pattern to do similar thing overriding modified() method on datasource fields. I would like to warn anyone using that pattern , that every screen in AX2009 SP0 will fail to behave as expected. Problem: When you re-read the contents of the record on the form using F5 function key, AX 2009 SP0 does call the datasource's active method, allowing you to re-set access ( _DS.object().allowEdit(...) ) but DOES NOT call *_DS.active() method when one press Ctrl-F5. Scenario of failure: User arrives at the record, enters some data , is allowed access to the other fields (based on previous input). Now user presses Ctrl-F5, and all field values return to initially fetched, but *_DS.active() method is not called, potentially making editable fields which were not available upon arrival to that record. User happily changes the data, and developer ask himself a question how did it happened. BTW: _DS.cursorNotify() is not called either. It would be good if someone would confirm this behaviour in AX4 and AX2009SP1 Solution: For the time being there's small generic solution to this. You need to modify the SysSetupFormRun.task() to make it call active() after Ctrl-F5 was pressed. public int task(int _p1) { #task FormDataSource formDataSource; int ret; if (_p1 == #taskFilter) { formDataSource = this.objectSet(); if (formDataSource && formDataSource.queryRun() && formDataSource.queryRun().args() && !formDataSource.queryRun().args().caller()) { formDataSource.queryRun().args().caller(this); } } ret = super(_p1); //mku------------------------------------------------- to call the datasource's active and allow re-setting the access---------- if(_p1 == 2839) { formDataSource = this.objectSet(); if(formDataSource) { formDataSource.active(); } } //mku ------------------------------------------------------ end ------------------------------------------------------------ return ret; } Источник: http://staticsax.blogspot.com/2009/0...s-control.html
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
