Старый 19.12.2008, 10:05   #1
Dianne Siebold: Import Credit Card Transactions for Expense Mgmt
Источник: http://blogs.msdn.com/dsiebold/archi...ense-mgmt.aspx
This post is from the “too helpful not to share” file. I received this information recently on how to import credit card transactions for expense management in Dynamics AX 2009.
To set up importing of credit card transactions into expense management, go to Basic > Setup > Import > Documents. Following is a high level walkthrough of how to set it up:
1. Navigate to Basic > Setup > Import.
2. Select Global settings.
3. Enter a location for log files and close the form.
4. Select Documents. Note that the first time the form is opened, there may be a delay.
5. Click CTRL+N to add a new row.
6. In the Document Name field, enter a document name such as Credit Card Import.
7. In the Document class drop down, select the AxdTrvPBSMaindata class.
8. After selecting that class change settings as appropriate. If you click Validate, it ensures that the selected document class is valid and that the logging path is valid and the current user has access rights to it.
9. Close the form
10. Select Transformations.
11. Click CTRL+N to add a new row if a new row has not already been added.
12. In the Transformation Name field, enter a value.
13. In the Document Name field, select the document that you defined in steps 5 – 9 that corresponds to the transformation.
14. In the Type of transformation field, select Binary to transform non-XML files or XLST to transform XML files.
15. Load and validate any transformation you have created. (Note: If you have an XML file that already corresponds to the schema expected by Dynamics AX, then you do not need to load any transformations).
16. Close the Transformations form.
17. Select Formats.
18. In the Format Name field, enter a name.
19. Select the corresponding document name from the Document Name drop down.
20. Mark the Active field.
21. If you have created more than one transformation, they can be added and sequenced on the form that will open if you click the Transformation button.
Once you have completed the steps above, navigate to Expense Management > Periodic > Credit Cards > Credit Card Import. You will not be able to open this form until you have created a format using the steps above. Once a format has been created you simply point to the location of the file you want to import, select the corresponding format defined in the steps above, and import to your heart’s content.
The DLL(s) or XSLT(s) need to be created outside of Dynamics AX. If the credit card file being imported is a non-XML file, then code needs to be written and put in a DLL to transform the file into a format the AX accepts. If the credit card file being imported is an XML file, then an XSLT can be written to transform the file into one that Dynamics AX will accept. Obviously, somebody who is relatively technical will need to do this.
We have provided a sample DLL for transforming a credit card transaction file from AMEX. This can be found on PartnerSource: https://mbs.microsoft.com/partnersource/documentation/howtoarticles/MD_AX50_Transformation_Sample (this requires a valid PartnerSource login).
Dynamics AX: In the spot light: Dianne Siebold's WebLog Blog bot DAX Blogs 0 17.09.2008 20:05
Arijit Basu: Credit Card Import Transformation Sample for Expense Management in Microsoft Dynamics AX 5.0 Blog bot DAX Blogs 0 12.02.2008 15:10
Dianne Siebold: Limit Outbound Documents in 4.0 (AIF) Blog bot DAX Blogs 0 12.01.2008 00:23
axcoder: Dianne Siebold's blog Blog bot DAX Blogs 0 15.10.2007 15:22
dynamicsusers: How Credit Card Processing Works Blog bot DAX Blogs 0 11.07.2007 04:39
Часовой пояс GMT +3, время: 11:06.
