Старый 12.12.2008, 13:05   #1
DeniZone: Setting Cross-reference update in a Schedueld task
Источник: http://denizone.blogspot.com/2008/10...update-in.html
An updated Cross reference is an indispensable tool when developing for AX but the client-side dependency can be annoying. So after a little research I found the command line parameter/Windows build-in Scheduled task combo and it does the trick.
In the class SysStartupCmd's construct the command line parameter compileAll-startup command the the parm _+ instantiates a complete compile and cross reference update which means that if you set-up a Scheduled task in Window's standart scheduled task tool with the parameter -startupcmd=compileAll_+ you can update when it suits your development team best.
Dianne Siebold: Rec Fields Required in AIF Partial Update Blog bot DAX Blogs 0 20.01.2009 09:05
axaptafreak: Catching keystrokes and the task() method Blog bot DAX Blogs 0 30.10.2007 17:10
Dianne Siebold: Update on the Dynamics AX SDK Team kashperuk DAX Blogs 1 16.10.2007 08:23
AX UK: Task Recorder Update Blog bot DAX Blogs 0 16.11.2006 08:40
Dynamics AX Geek: cross-references & find Blog bot DAX Blogs 0 28.10.2006 16:40
Часовой пояс GMT +3, время: 05:07.
