Старый 18.11.2008, 10:05   #1
epblog: Filtering a DataSet from Code behind
Источник: http://blogs.msdn.com/epblog/archive...de-behind.aspx
Enterprise portal allows filtering the list pages using the Filter control available on the EP Grid. The Filter control provides a UI to select the field, criteria and the values you want to filter the grid. It is also possible to add multiple conditions....(read more)
Dynamics AX: Microsoft Dynamics AX EP Team Blog - Filtering a DataSet from Code behind Blog bot DAX Blogs 0 04.12.2008 03:07
axStart: Starting the code profiler from code Blog bot DAX Blogs 0 17.03.2008 15:05
axaptafreak: Open web pages from X++ code Blog bot DAX Blogs 0 12.03.2008 16:05
Часовой пояс GMT +3, время: 16:46.
