Старый 03.07.2008, 14:05   #1
AX Developer tips: Updating records without FORUDATE statement
Источник: http://axdevposts.blogspot.com/2008/...-forudate.html
I had an experience on previous project when I couldn't have inserted record in database because it was selected from another scope on server with forupdate parameter and then passed to another class to either insert or update it. Such kind of transfer was made due to abstraction of record initializer and to have the only place where record is written to DB.
The error saying that record was not selected for update was thrown.
But solution can be found in "Inside Dynamics AX" book.
The skipTTSCheck method can be called with parameter true on record in place where the record is written.
So by forcing skip of TTS check even record which was not selected for upadate can be written.
Though "last writer" rule applies here...
Anyway this record processing was expected to take place only from single machine at one concrete moment of time using batch processing.
AX Developer tips: Dynamics AX Team Server Blog bot DAX Blogs 0 22.07.2008 21:05
AX Developer tips: Dynamics AX Performance issue. Cross object references drawbacks. Blog bot DAX Blogs 0 14.07.2008 00:11
AX Developer tips: CLR Interoperbility. Problem with Assembly Versions Blog bot DAX Blogs 0 03.07.2008 14:05
AX Developer tips: .NET enumerations in Dynamics AX Blog bot DAX Blogs 0 03.07.2008 14:05
Часовой пояс GMT +3, время: 05:55.
