Старый 30.04.2008, 23:07   #1
dax-lessons: Create Outlook Appointment or Meeting Request using X++
Источник: http://DAX-Lessons.spaces.live.com/B...FCD1!153.entry
If you need to create an appointment or meeting request in Outlook using X++, just borrow the code below. Outlook client needs to be installed on themachine where the code is run.
Here is the job.
static void OutlookAppointment(Args _args)
   COM        sysOutlookCollection;
   COM        collection;
   COMVariant comStartDate = new COMVariant();
   COMVariant comEndDate   = newCOMVariant();
   COM        c;
   #SysOutLookCOMDEF
   #define.mapi("MAPI")
   #define.outlook("Outlook.Application")
   COM        sysOutlook;
   COM        sysOutlookNameSpace;
   COM        sysOutlookMAPIFolder;
   sysOutlook                  = newCOM(#outlook);
   sysOutlookNameSpace         = sysOutlook.getNamespace(#mapi);
   sysOutlookNameSpace.logon();
   sysOutlookMAPIFolder        =sysOutlookNameSpace.getDefaultFolder(#OlDefaultFolders_olFolderCalendar);
   collection                  =sysOutlookMAPIFolder.items();
    c =collection.add();
   comStartDate.date(today());
   comStartDate.time(str2Time( "12:00:00"));
   comEndDate.date(today());
   comEndDate.time(str2Time( "12:45:00"));
   c.location('Solugenix 4th Floor Conference Room, India');
   c.subject('Meeting regd Microsoft Dynamics AX 2009');
   c.body('Lets discuss on whats new in DAX 2009');
   c.start(comStartDate);
   c.end(comEndDate);
   c.save();
    if (c)
       c.display();
       info("The action is created in Microsoft Outlook");
    else
       throw error("@SYS31969");
       sysOutlookNameSpace.logoff();
dax-lessons: Generate XML Documentation Files for a project - DAX 2009 Blog bot DAX Blogs 0 08.08.2008 19:06
dax-lessons: Create HTML using HtmlTextWriter class in x++ Blog bot DAX Blogs 0 15.04.2008 20:05
dax-lessons: Create Technical Document from AX Blog bot DAX Blogs 0 12.03.2008 09:05
dax-lessons: Document Handling in AX - setup and Example Blog bot DAX Blogs 0 27.08.2007 23:00
dax-lessons: Active directory in Axapta Blog bot DAX Blogs 0 27.08.2007 23:00
Часовой пояс GMT +3, время: 23:41.
