Старый 16.04.2008, 02:11   #1
Solutions Monkey: Forcing NTLM on IISWebsite
Источник: http://blogs.msdn.com/solutions/arch...iswebsite.aspx
(1) Go to IISManager and find the identifier for your Web Site. Click on the web sites folder in IISManager and on the left side you should get the list of web sites and their identifier
(2) Open a command prompt and runt the following 3 commands. Change the with the identifier value found in the previous step
cd c:\inetpub\adminscripts
cscript adsutil.vbs set w3svc//root/NTAuthenticationProviders "NTLM"
iisreset
NOTE:
(1) if you want to set NTLM at a virtual direcotry level then use the below command and replace with the virutal directory name
cscript adsutil.vbs set w3svc//root//NTAuthenticationProviders "NTLM"
(2) To revert back to Kerberos use "Negotiate,NTLM" as the parameter
(3) To check what is currently set use the below commands
cscript adsutil.vbs get w3svc//root/NTAuthenticationProviders
cscript adsutil.vbs get w3svc//root//NTAuthenticationProviders
Solutions Monkey: Microsoft Dynamics AX 2009 Enterprise Portal / Role Centers - Deployment Tips-n-Tricks – 3 Blog bot DAX Blogs 0 27.10.2008 08:05
Solutions Monkey: Aggregation in EP Datasets Blog bot DAX Blogs 0 07.10.2008 06:05
Solutions Monkey: Role Center Security Blog bot DAX Blogs 0 28.05.2008 16:05
Solutions Monkey: Forcing NTLM on IISWebsite Blog bot DAX Blogs 0 28.05.2008 16:05
Solutions Monkey: EP 4.0 Questions Blog bot DAX Blogs 0 28.10.2006 16:40
Часовой пояс GMT +3, время: 04:17.
