Старый 04.04.2008, 11:05   #1
msdynamicsax: Task Recorder
Источник: http://msdynamicsax.wordpress.com/20...task-recorder/
Some of you might have used this tool alreadyas it was given away as an add-on tool from MS for Ax 4.0. So, the question is; has it changed since 4.0? Actually, it has changed a little bit. You can now also easilly capture screens manually while recording a task. Other than that, it looks the same.
axaptapedia: Task Recorder Blog bot DAX Blogs 6 29.06.2008 21:01
msdynamicsax: User Interface Blog bot DAX Blogs 0 04.04.2008 11:05
AX UK: See Task Recorder in Action Blog bot DAX Blogs 0 07.12.2006 20:30
AX UK: Task Recorder Update Blog bot DAX Blogs 0 16.11.2006 08:40
AX UK: Task Recorder For Microsoft Dynamics AX Blog bot DAX Blogs 0 11.11.2006 00:01
Часовой пояс GMT +3, время: 07:36.
