Старый 18.03.2008, 03:14   #1
C# and AX Development: Printing directly to PDF in AX
Источник: http://olondono.blogspot.com/2008/03...ly-to-pdf.html
References: AxaptaPedia
To achieve this task, we need to set some values to the printing settings before running the report like this:
// Variables
PrintJobSettings    printJobSettings;
ReportRun           myReportRun;
// Getting the report settings
printJobSettings = myReportRun.printJobSettings();
// Setting our parameters
printJobSettings.setTarget(PrintMedium::File);
printJobSettings.preferredTarget(PrintMedium::File);
printJobSettings.format(PrintFormat::PDF);
printJobSettings.preferredFileFormat(PrintFormat::PDF);
printJobSettings.fileName("c:\\attachment.pdf");
// Saving values
myReportRun.unpackPrintJobSettings(printJobSettings.packPrintJobSettings());
// Running the report
myReportRun.run();
Before running the report, we can set query's values:
query = myReportRun.query();
qbds = query.dataSourceNo(1);
qbds.range(1).value(_custTable.CustAccount);
qbds.range(2).value("");
qbds.range(3).value(queryvalue(NoYes::Yes));
myReportRun.run();
NOTE: For using a PDF Printer like "PDFCreator", simply set the deviceName like this:
myReportRun.deviceName("PDFCreator");
Часовой пояс GMT +3, время: 13:49.
