Старый 23.02.2008, 19:37   #1
mfp: Writing less code: The "else" statement
Источник: http://blogs.msdn.com/mfp/archive/20...statement.aspx
Source code is written once; and read over and over again. So make sure it is easy to read and understand.
I keep seeing a poor coding practice. I see it in production code, in test code, in X++ code, in C# code, in C++ code, in examples on the web, when interviewing candidates. I see it where ever I look. It is a practice that adds unnecessary complexity to source code, it make the source code harder to read, and harder to write. And what disturbs me the most is, how easy it is to avoid.
Take a look at this simple code:
<DIV class=source>boolean isNegative(int value)
if (value
mfp: Do you want to write more secure code? Blog bot DAX Blogs 0 26.03.2008 18:05
mfp: Anyone interested in developer documentation of X++ code? Blog bot DAX Blogs 0 19.02.2008 18:50
mfp: Sneak preview - Code Upgrade Enhancements Blog bot DAX Blogs 0 02.03.2007 20:46
mfp: Writing Secure X++ Code Blog bot DAX Blogs 0 28.10.2006 16:47
Часовой пояс GMT +3, время: 07:53.
