Старый 22.01.2008, 21:33   #1
axaptafreak: Getting new table fields into your form datasource
Источник: http://axaptafreak.blogspot.com/2008...your-form.html
When you create new fields in a table and then go into a form where this table is used, you will not see the new fields in the forms datasource. You could be tempted to go into the properties of the datasource and re-select the table (which would actually add all the new fields).
BUT: Don't do it! You will loose all your modifications and methods made in the datasource !
Better: just exit the Dynamics AX client and enter again. Then, all new fields will appear in your datasource. Helmut Wimmer
DeniZone: Invoking a method on a field in a form's datasource Blog bot DAX Blogs 0 13.02.2009 14:05
daxmy: Tips: Enable company/user template when created new form with new table Blog bot DAX Blogs 2 18.10.2007 11:38
Issues concerning X++: Integrating Mappoint into the Customer form... Blog bot DAX Blogs 0 12.07.2007 05:56
PatrickChua: Temporary table Blog bot DAX Blogs 0 28.10.2006 18:14
Часовой пояс GMT +3, время: 10:32.
