Старый 10.01.2008, 23:17   #1
axStart: Adding your AX pictures to you SharePoint Site
Источник: http://axstart.spaces.live.com/Blog/...C0A0!228.entry
<div>
Adding your AX pictures to you SharePoint Site:
When we look at AX and press the button ‘publish images’ we don’t see match happen. The reason is that the current code is simply not working. I have added the fix for this code in this article.
Take a close look at class SysEPDeployment, method deployCompanyImages. In They simply looked at the wrong fields
<font face=Arial><font size=2>for<span lang=EN-GB style=""><font color="#000000"> (loop=1;loop
Fred Shen: Add an AX user to be a memebr of Sharepoint site group Blog bot DAX Blogs 0 26.08.2008 11:05
axStart: AXC configuratied SharePoint AX configuration. Blog bot DAX Blogs 0 17.01.2008 03:30
axStart: Checklist when AX is not working with SharePoint Blog bot DAX Blogs 0 10.01.2008 23:17
Часовой пояс GMT +3, время: 01:58.
