Старый 29.12.2007, 19:50   #1
Ruslan Goncharov: Mandatory property for DialogField
Источник: http://rusgon.blogspot.com/2007/12/m...alogfield.html
Usually in Dialog Forms it's unable to set mandatory property for Dialog Fields. The lack of this property sometimes annoyed me. At the end I've decided to eliminate this gap :-)
To expand the standard functionality you need to do the following steps:
1.Add mandatory() method into DialogField class:
// Created by GRR on 01.11.2005
void mandatory(boolean r)
    str name;
    // If properties exists then we are on server
    if (properties)
        name = #Propertymandatory;
        if (! properties.exists(name))
            properties.add(name,true);
        properties.value(name,r);
    else
        this.fieldControl().mandatory(r);
2. Add into unpack() method following lines:
case #PropertyMandatory:
    this.mandatory(unpackedProperties.valueIndex(i));
    break;
Now you may enjoy mandatory property in Dialog Forms.
This trick published in Axaptapedia too.
Ruslan Goncharov: A few words about sorting codes Blog bot DAX Blogs 0 18.02.2009 21:05
Ruslan Goncharov: Dynamic enabled() property for StringEdit and arrows Blog bot DAX Blogs 0 18.04.2008 20:05
Ruslan Goncharov: Sending message to user Blog bot DAX Blogs 0 26.01.2008 18:22
Ruslan Goncharov: How to clarify what happened with variables in AX Blog bot DAX Blogs 0 17.01.2008 15:40
Ruslan Goncharov: How to get the screenshots of all open windows in AX Blog bot DAX Blogs 0 12.01.2008 12:31
Часовой пояс GMT +3, время: 09:47.
