Старый 18.12.2007, 19:50   #1
gatesasbait: Forcing specific layers to compare in Ax 4.0x
Источник: http://gatesasbait.spaces.live.com/B...B9F5!158.entry
Good morning again!
I'm stuck compairing a lot of objects for a customer's migration project. For example, last week, I had about one hundred tables, forms and classes to compare between the 'bus' and 'old bus' layers. In Ax5, the compare tool remembers your previous layer selections, but in Ax4, there is not such functionality. Therefore I added this code in class 'SysCompare', standard method 'initContext' (it can definitely be improved):
protected void initContext(SysCompareContextProvider _context)
    while (!(comboBox1.getText(comboBox1.selection()) like "*(bus)*"))
        if (!comboBox1.getText(comboBox1.selection()))
            comboBox1.selection(0);
            break;
        comboBox1.selection(comboBox1.selection()+1);
    while (!(comboBox2.getText(comboBox2.selection()) like "*(old bus)*"))
        if (!comboBox2.getText(comboBox2.selection()))
            comboBox2.selection(0);
            break;
        comboBox2.selection(comboBox2.selection()+1);
gatesasbait: Showing Database name of current AOS in AX 4.0x title bar Blog bot DAX Blogs 0 18.12.2007 19:50
gatesasbait: On Dynamics Ax 5.0 compare tool enhancements Blog bot DAX Blogs 3 29.11.2007 13:42
gatesasbait: About local Dynamics Ax 4.0x installations on Windows XP Blog bot DAX Blogs 0 28.11.2007 06:32
Часовой пояс GMT +3, время: 09:54.
