Старый 16.11.2007, 04:23   #1
axaptapedia: Macrolabel
Источник: http://www.axaptapedia.com/Macrolabel
Summary: New page: [[Macrolabel]] is a [[macro]], which purpose it only to mark some code. The only example I know is [[InventDimDevelop macro]] which is "used to locate code with direct dimension references...
[[Macrolabel]] is a [[macro]], which purpose it only to mark some code. The only example I know is [[InventDimDevelop macro]] which is "used to locate code with direct dimension references"
axcoder: PowerShell + Ax Blog bot DAX Blogs 1 09.01.2009 18:05
axaptapedia: Load Web Documents Blog bot DAX Blogs 1 03.01.2009 23:50
axaptapedia: DEV TabaxPlugin RecentProjects Blog bot DAX Blogs 0 14.05.2007 18:00
axcoder: AxPath is supported by axaptapedia Blog bot DAX Blogs 0 11.05.2007 10:00
Часовой пояс GMT +3, время: 14:55.
