#1 |
gl00mie: Run DAX4 AOS as a console application
Источник: http://gl00mie.blogspot.com/2007/10/...plication.html
============== I've recently found an interesting feature of DAX4 Object Server: it can run not only as a service, but also as a console application started from command line. All you have to do is pass a console parameter before the configuration number, e.g. This feature was probably added for debugging purpose as it's rather difficult to start a Windows service under a debugger. When started as a console application AOS can be terminated by pressing Ctrl-C or Ctrl-Break. Источник: http://gl00mie.blogspot.com/2007/10/...plication.html
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
