Старый 21.04.2007, 18:28   #1
Arijit Basu: Windows Server Support Matrix For DAX
Источник: http://daxguy.blogspot.com/2007/04/w...x-for-dax.html
A support matrix is available which will help you decide the version/service pack level of Windows Server that is compatible with your version of Microsoft Dynamics AX. It details out the compatibility issues regarding DAX on 32 bit & 64 bit systems.
Windows™ Server Support Matrix For Microsoft Dynamics™ AX
Windows™ 64-bit Operating System support matrix for Microsoft Dynamics™ AX 4.0 SP1
{Requires partnersource logon}
Arijit Basu: PerformancePoint Server 2007 Tool: Data Import Wizard for Microsoft Dynamics AX Blog bot DAX Blogs 0 22.01.2008 21:33
Arijit Basu: Microsoft SQL Server Reporting Services Integration Blog bot DAX Blogs 0 20.07.2007 11:50
Arijit Basu: Microsoft SQL Server Reporting Services Integration Blog bot DAX Blogs 0 28.06.2007 17:00
Client Axapta 3.0 SP4 и Linux. Как запустить? Daiver DAX: Администрирование 10 28.06.2007 15:59
Arijit Basu: Search Windows Live from AX Blog bot DAX Blogs 0 02.06.2007 17:13
Часовой пояс GMT +3, время: 02:00.
