Старый 20.04.2007, 01:14   #1
Kashperuk Ivan: Two very useful projects for DAX
Источник: http://kashperuk.blogspot.com/2007/0...s-for-dax.html
1. DEV_FormControlInfo
Today I downloaded a very nice project for DAX 4.0 from www.axaptapedia.com
It inserts a number of lines of code into the SysSetupFormRun class, method task, providing a hotkey to access usefull information about any control on a form.
The hotkey is 'Ctrl + Q'.
Here is a screenshot of the result:
I moved the project to DAX 3.0, because I liked it a lot. Previously I used the Tabax button, which is convenient too, but does not provide as much info as posted above.
Here is the download link for the project:2. DEV_AxFind
Also, my friend AndyD created a very good project for DAX 4.0
Description: After moving to DAX 4.0 a lot of users complained about the 'Ctrl + F' key combination. Now, instead of a 'Filter by Field' operation it opens a 'Global Search' window, which is uneasy to use so far.
Anyway, AndyD created a small dll file that replaces the 'Ctrl + K' key combination with the 'Ctrl + F' key combination, leaving the 'Global Serach' intact, but, at the same time, providing a well known interface for DAX users.
Thanks again, AndyD. :)
All you have to do is download the dll file (donwload link) and add the following lines of code into the Info class:
2.1. Info\classDeclaration
classDeclaration
DLL dllAxFind;
2.2. Info\startupPost
void startupPost()
InteropPermission perm = new InteropPermission(InteropKind::DllInterop);
// DEV_AxFindReplacement Replace Keys F and K when used with the Ctrl key 19.04.2007 IKASH -->
perm.assert();
dllAxFind = new dll(@"D:\Install\Dynamics AX\Dynamics AX 4.0 SP1 EE\axfind.dll");
CodeAccessPermission::revertAssert();
Kashperuk Ivan: Microsoft Dynamics AX 2009 Keyboard shortcuts Blog bot DAX Blogs 5 18.12.2013 18:24
Kashperuk Ivan: Tabax plugins' update - RecentWindows, RecentProjects Blog bot DAX Blogs 0 27.06.2007 21:40
Kashperuk Ivan: 3 great Tabax Plugins Blog bot DAX Blogs 2 15.05.2007 11:55
Kashperuk Ivan: Buy MorphX IT in Russian Blog bot DAX Blogs 6 13.04.2007 17:48
Kashperuk Ivan: A little modification / add-on to Sidax:I use on... Blog bot DAX Blogs 0 26.01.2007 05:51
Часовой пояс GMT +3, время: 23:59.
