Старый 22.03.2007, 21:41   #1
casperkamal: Creating custom Picking list in Dynamics - Part II
Источник: http://casperkamal.spaces.live.com/B...CD63!253.entry
This is in continuation to the article that i posted on creating custom Picking List (click to view)
 The last aritcle was about using the Global::pickList forms and creating a simple custom Pick List form which takes map as an input
The custom Picklist's discussed here provide you more options like
   >Specifying the image to be used
   >Display either a Map or container in the list
There are two ways of creating a complete custom Pick List
 'SysPick' form can be used to create custom list with the choice of taking input as Map and displaying standard images like tables, class, fields, You can invoke the "SysPick" form via the classfactory.
                      args = new Args(formstr(SysPick));
                      args.parm(' 2');
                      map = Map::create(SysPickList::fillFieldsMap(int2str(tablenum(custTable))));
                      args.parmObject(map);
                      formRun = classfactory.formRunClass(args);
                      formRun.init();
                      formRun.run();
                      formRun.wait();
                      if (formRun.selection())
                                 //TODO someAction
   Here
        > The argument for the "args.parm(' 2')" method decides the image type to be displayed.
                      - The argument value is to be based on the following EnumType "SysPickListType"
                         but has to be passed as a string and a blank space before the value is mandatory
        > SysPickList class has some static function that gives you a map of several repeated lists
            like fields, table, userdomain, class etc. you can use it to get the list to be passed as shown in the code
            map = Map::create(SysPickList::fillFieldsMap(int2str(tablenum(TestAdo))));
The other form is "PickList", this accepts any image for display and requires the list input as a container. The follwoing code demonstrates the way using it.
                            Object formRun;
                            #ResAppl
                            formRun = classfactory.createPicklist();
                            formRun.init();
                            formRun.choices(['option1', 'option2', 'option3'], #ImageArrowUp);
                            formRun.caption("Testing Picklist");
                            formRun.run();
                            formRun.wait();
                           if (formRun.choice())
                                  //TODO someAction
would result in  some thing like this
 ........................... happy picking !!!!!
Creating Custom Dynamics AX Services Blog bot DAX Blogs 0 17.12.2008 12:05
JOPX: Integrating MOSS 2007 and Dynamics AX Part II - installing and configuring Dynamics AX Enterprise Portal Blog bot DAX Blogs 0 02.03.2008 06:42
Inside Dynamics AX 4.0: Wizard Framework Extension Part II Blog bot DAX Blogs 0 29.09.2007 19:00
Dynamics AX: .Net BC Custom App, Part II Blog bot DAX Blogs 0 06.06.2007 10:07
casperkamal: Creating a Custom Display List - Blog bot DAX Blogs 0 27.12.2006 17:20
Часовой пояс GMT +3, время: 01:14.
