Старый 28.10.2006, 18:22   #1
Axapta Lessons: Axapta DLLs
Источник: http://axapta-lessons-learned.blogsp...apta-dlls.html
What is a DLL?
A dynamic-link library (DLL) file is an executable file that allows programs to share code and other resources necessary to perform particular tasks.
A DLL provides one or more particular functions. Programs accesses these functions by creating either a static or dynamic link to the DLL. A static link remains constant during program execution while a dynamic link is created by the program as needed.
A DLL can be used by several applications at the same time. Some DLLs are provided with the Windows operating system and available for any Windows application. Other DLLs are written for a particular application and are loaded with the application.
DLL files usually end with the extension .dll,.exe., drv, or .fon.
Kernel.exe, User.exe and Gdi.exe are examples of DLLs with .EXE extensions. They provide code, data or routines to programs running in the Windows operating system.
DLLs may be found in the Windows directory, Windows\System directory or in an program's directory.
Static and Dynamic Linking
Usually, programmers use static linking when using functions in a DLL. This is the most easiest way to use a DLL. However, if a DLL is missing, application cannot be started. This is not a big problem: missing DLL means that something is wrong with application installation and the application should not be started anyway.
If an application is designed in such a way as to offer some optional features with the help of one or more DLLs, missing DLL should not prevent the application to run normally (but without optional features). In this case, DLL must be loaded dynamically.
Axapta DLLs
In the Bin directory of the Client and Server we can find several DLL-files. These DLL-files are either created by Microsoft or by third parties.
DLL-Files found in the BIN directory
- AnaMeter.dll
Provided by: Circle Capital A/S
Web site: www.circlecapital.com
Purpose: Used in Balanced Scorecard and Questionnaire
Type:
- aspupload.dll
Provided by: Persits Software, Inc.
Web site: www.aspupload.com
Purpose:
AspUpload is a COM+ component which enables an ASP application to capture, save and process files uploaded to the web server with a browser. The files are selected for uploading via an HTML POST form using the tag.
With AspUpload, you can add file upload functionality to your Web application in as little as 2 lines of ASP script. In addition to uploading, AspUpload offers a wide range of file management functions, including secure downloading, saving files in the database, permission and attribute management, image size extraction, file encryption, etc.
- AxaFiles.dll
Provided by:
Web site:
Purpose:
Type:
- AxCfg300.dll
Provided by: Microsoft Business Solutions ApS
Web site:
Purpose: Used by the Axapta Configuration Utility (AxConfig.exe)
Type:
- AxCom.dll
Provided by:
Web site:
Purpose: COM Connector
Type:
- AxComps.dll
Provided by: Navision a/s
Web site:
Purpose: DCOM Client
Type:
- AxHotLib.dll
Provided by:
Web site:
Purpose: Handling function keys (F1-F10) in SFC
Type:
- Bcfont32.dll
Provided by:
Web site:
Purpose: Used for Bar code
Type:
- CFX2032.dll
Provided by:
Web site:
Purpose:
Type:
- dbghelp.dll
Provided by:
Web site:
Purpose:
Type:
- DSMailer.dll
Provided by: Dundas Software
Web site: http://www.dundas.com
Purpose:
Type:
- gear32pd.dll
Provided by: AccuSoft Corporation
Web site: www.accusoft.com
Purpose:
Type:
- iglzw32s.dll
Purpose:
Type:
- mfc71.dll
Provided by: Microsoft Corporation
Web site:
Purpose:
Type:
- msvcp71.dll
Web site:
Purpose:
Type:
- msvcr71.dll
Web site:
Purpose:
Type:
- smmaxol.dll
Provided by: Hands ASA
Web site: http://www.hands.no/
Purpose: Used in synchronization between Outlook and Axapta
Type:
- tlbinf32.dll
Provided by:
Web site:
Purpose:
Type:
- vc6-re200l.dll
Web site:
Purpose:
Type:
- vcpanes32.dll
Provided by: NETRONIC Software GmbH
Web site: >http://www.netronic-us.com/
Purpose:
Type:
- vcprct32.dll
Web site: http://www.netronic-us.com/
Purpose: Used by VarChart (Gantt Applications)
Type:
- vcsced32.dll
Type:
- vcwin32.dll
Type:
- vxcsv32.dll
Type:
dax-lessons: Active directory in Axapta Blog bot DAX Blogs 0 27.08.2007 23:00
Axapta Lessons: Integrating Microsoft Axapta with Microsoft Office and Microsoft SharePoint Blog bot DAX Blogs 0 28.10.2006 18:22
Axapta Lessons: Creating an IBF Compliant Web Service for Axapta Blog bot DAX Blogs 0 28.10.2006 18:22
Axapta Lessons: Reporting tools Blog bot DAX Blogs 0 28.10.2006 18:22
Часовой пояс GMT +3, время: 06:31.
