Старый 28.10.2006, 16:40   #1
Fred Shen: Adding covering indexes for aggregate function
Источник: http://fredshen.spaces.live.com/Blog...E4E3!158.entry
It is always recommended to use aggregate function (like sum, avg, minof, maxof and count) in queries where applicable in Axapta. If you run this kind of query frequently, it is considerable to add a covering index for the query. A covering index is an index, which includes all of the columns referenced in the query.
And what is the reason? Because SQL Server can use these entries in the index's leaf level to perform aggregate calculations. This means that the index contains the data you are looking for, and SQL Server does not have to go to the actual table to perform the aggregate calculations, which can boost performance.
dynamicsusers: NAV SQL Tuning - Covering Indexes Blog bot DAX Blogs 0 27.04.2007 17:10
Fred Shen: Change the combobox options in RunbaseBatch class Blog bot DAX Blogs 0 28.10.2006 16:40
Fred Shen: Convert Axapta date type value to datetime type value in SQL Server Blog bot DAX Blogs 0 28.10.2006 16:40
Fred Shen: Tips on optimizing primary index in Axapta Blog bot DAX Blogs 0 28.10.2006 16:40
Fred Shen: Development Features of Dynamics Ax (Axapta) 4.0 Blog bot DAX Blogs 0 28.10.2006 16:40
Часовой пояс GMT +3, время: 04:27.
