Старый 28.10.2006, 16:40   #1
Fred Shen: Consuming a Web Service in Dynamics AX 4
Источник: http://fredshen.spaces.live.com/Blog...E4E3!188.entry
This will tell you how to use Common Language Runtime Interoperability feature in Dynamics AX 4 to reference a web service.  There is a pretty good discussion about this on Microsoft MBS community by Dilip and Mike Frank.
To continue, at least you need to have Dot Net Framework SDK 2.0.  (Not Visual Studio .Net) We will use the language translation service on www.stanski.com as the referenced web service.
Procedure:
Download and Install .NET Framework Version 2.0 Software Development Kit.
Open a Microsoft .NET Framework command prompt. Click Start, point to All Programs, point to Microsoft .NET Framework SDK 2.0, and then click SDK Command Prompt.
At the command prompt, run the following command:
Wsdl /l:cs /protocol:soap
http://www.stanski.com/services/translate/translate.asmx
This will generate a C# source code file of proxy classe, which in this situation is TranslationService.cs
Then we need to edit TranslationService.cs file to add namespace for it.
Use NotePad to edit TranslationService.cs, the edited codes should look like
namespace DemoAXWebService //Add namespace declaration
    using System;
}//End namespace declaration
Compile the cs file to dll file. Type this in the command prompt
csc /t:library TranslationService.cs
This will generate the TranslationService.dll.
Copy the TranslationService.dll to \Program Files\Microsoft Dynamics AX\client\Bin.
Start Microsoft Dynamics AX 4.0
Open Application Object Tree, and locate the Reference node. Right click, select Add Reference and register the TranslationService.dll in Dynamics AX.
Create a new job named TestWebService
static void TestWebService(Args _args)
    DemoAXWebService.TranslationService translateService
     = new DemoAXWebService.TranslationService();
    str strLanguage, strMessage;
    str translateResult;
    strLanguage = 'en_de';
    strMessage  = 'Test Web Service';
    translateResult = translateService.Translate(strLanguage, strMessage);
    Info(translateResult);
Run the job, you will get the result “Test-Netz-Service”.
Dynamics AX: WCF: The Enterprise Service Bus for Dynamics AX and the rest of the Microsoft Stack Blog bot DAX Blogs 0 10.03.2009 16:05
Consuming External Web Services (Dynamics AX 4) Blog bot DAX Blogs 0 19.02.2008 06:41
Inside Dynamics AX 4.0: The Web Framework Blog bot DAX Blogs 0 25.10.2007 03:04
Pokluda: Outbound web service (AIF) Blog bot DAX Blogs 0 28.10.2006 17:43
Часовой пояс GMT +3, время: 23:39.
