Старый 12.05.2006, 10:08   #1
Jul_Sol is offline
Jul_Sol
? Проблемы с laptop клиентом в CRM 3.0
В процессе установки ишет ошибку
"Ошибка действия Microsoft.CRM.Setup.Client.InstallPstAction.
Ошибка AddAccessAllowedAce". После этого установка прерывается.
Что в таком случае можно сделать?? Куда смотреть??
Старый 22.06.2006, 16:05   #2
caesar is offline
caesar
Пользуйтесь поиском на буржуйских просторах ))
Microsoft.Crm.Setup.Client.InstallPstAction failed
Yes after some testing, research and a great supportteam we have the answer to some
weird errors when installing the Microsoft CRM client through GPO.
The following error occurs:
13:46:27| Info| Executing Install action: Microsoft.Crm.Setup.Client.ReleasePassAction
13:46:27| Info| Executing Install action: Microsoft.Crm.Setup.Client.DeleteHotFixesAction
13:46:27| Info| Executing Install action: Microsoft.Crm.Setup.Client.InstallPstAction
13:46:27| Error| AddAccessAllowedAce failed.(error = 1337) (permissions.cpp:CPermissions::CreateNewSd:353).
13:46:27| Error| System.Exception: Actie Microsoft.Crm.Setup.Client.InstallPstAction is mislukt. ---> System.Runtime.InteropServices.COMException (0x80070539): AddAccessAllowedAce failed.
Resolution:
The following workaround is available.
Create on your local box a “local group” or “local user” account called “INTERACTIVE”.
This can be done like this:
Logon as Domain Admin or user with local admin privileges
Goto Start -> System settings -> User accounts -> Tab Advanced -> Advanced
Now you can select creating a user account or a group account. If you select a group account, make sure that the local user is member of the group.
Run the CRM client setup again.
Часовой пояс GMT +3, время: 08:15.
