Старый 10.05.2019, 02:33   #3
MarinaAX is offline
MarinaAX
134 / 57 (2) ++++
  1. IIS логи - пустые.
  2. Сертификаты - годные. Повторное развёртывание сертификатов не помогло.
  3. Т.к. ошибка 500 - общая, то вот подробности из Application лога:
    Warning 5/9/2019 11:23:34 PM ASP.NET 4.0.30319.0 Event ID: 1310 Web Event
    Event code: 3007
    Event message: A compilation error has occurred.
    Event time: 5/9/2019 11:23:34 PM
    Event time (UTC): 5/9/2019 11:23:34 PM
    Event ID: bfd742354c8441f881bcbd69e5ce2878
    Event sequence: 3
    Event occurrence: 1
    Event detail code: 0
    Application information:
    Application domain: /LM/W3SVC/2/ROOT-74-132019178132609156
    Trust level: Full
    Application Virtual Path: /
    Application Path: K:\AosService\WebRoot\
    Machine name: AX3
    Process information:
    Process ID: 1852
    Process name: w3wp.exe
    Account name: NT AUTHORITY\NETWORK SERVICE
    Exception information:
    Exception type: HttpCompileException
    Exception message: k:\AosService\WebRoot\App_Code\Global.asax.cs(30): error CS0234: The type or namespace name 'Extensions' does not exist in the namespace 'Microsoft' (are you missing an assembly reference?)
    at System.Web.Compilation.AssemblyBuilder.Compile()
    at System.Web.Compilation.BuildProvidersCompiler.PerformBuild()
    at System.Web.Compilation.CodeDirectoryCompiler.GetCodeDirectoryAssembly(VirtualPath virtualDir, CodeDirectoryType dirType, String assemblyName, StringSet excludedSubdirectories, Boolean isDirectoryAllowed)
    at System.Web.Compilation.BuildManager.CompileCodeDirectory(VirtualPath virtualDir, CodeDirectoryType dirType, String assemblyName, StringSet excludedSubdirectories)
    at System.Web.Compilation.BuildManager.CompileCodeDirectories()
    at System.Web.Compilation.BuildManager.EnsureTopLevelFilesCompiled()
    at System.Web.Compilation.BuildManager.CallAppInitializeMethod()
    at System.Web.Hosting.HostingEnvironment.Initialize(ApplicationManager appManager, IApplicationHost appHost, IConfigMapPathFactory configMapPathFactory, HostingEnvironmentParameters hostingParameters, PolicyLevel policyLevel, Exception appDomainCreationException)
    Request information:
    Request URL: https://ax3-url.cloudax.dynamics.com:443/
    Request path: /
    User host address: 127.0.0.1
    User:
    Is authenticated: False
    Authentication Type:
    Thread account name: NT AUTHORITY\NETWORK SERVICE
    Thread information:
    Thread ID: 6
    Is impersonating: False
    Stack trace: at System.Web.Compilation.AssemblyBuilder.Compile()
    Custom event details:
Заранее, большое спасибо за помощь!
error 500
D365 FO - Ошибка A network-related or instance-specific error occurred while establishing a connection to SQL Server MarinaAX DAX: Программирование 6 24.07.2018 07:22
Проблемы с возможностью изменения запроса после установки ТТН на Ax2009 RU7 Zan DAX: Программирование 2 12.08.2011 12:02
Установка Reporting Services не активна в выборе компонентов программы установки SQL Server 2005. em# DAX: Администрирование 1 19.01.2010 12:01
Инкрементная компиляция после установки SP3 Shirmin Oleg DAX: Администрирование 7 04.06.2004 13:02
Часовой пояс GMT +3, время: 20:17.
