Старый 09.10.2017, 09:47   #5
trud is offline
trud
1,039 / 1635 (57) ++++++++
то exception.
Так и что будет делать пользователь с этим exception?
chain of command
Kashperuk Ivan: Development Tutorial: Extensibility: Adding a table display/edit method and showing it on a form in PU11 Blog bot DAX Blogs 2 09.10.2017 13:36
Kashperuk Ivan: Development Tutorial: Extensibility: Adding a table display/edit method and showing it on a form in PU10 Blog bot DAX Blogs 20 07.10.2017 12:42
Kashperuk Ivan: Development tutorial: SysExtension framework with SysExtensionIAttribute and an Instantiation strategy Blog bot DAX Blogs 0 01.04.2017 02:17
Kashperuk Ivan: Development tutorial link: Extensibility challenges: Pack/Unpack in RunBase classes Blog bot DAX Blogs 0 01.04.2017 02:17
Kashperuk Ivan: Development tutorial: SysExtension framework in factory methods where the constructor requires one or more arguments Blog bot DAX Blogs 4 19.03.2017 23:56
Часовой пояс GMT +3, время: 21:55.
