Старый 29.03.2017, 22:16   #8
skuull is offline
skuull
700 / 752 (27) +++++++
The X++ compiler now generates code that is slightly different for try catch blocks. Before, the system would catch the DuplicateKey and UpdateConflict exceptions as part of the catch all clause. This introduced some problems that could ultimately lead to data consistency problems if the try catch was used when a transaction is running. Now, the two exceptions mentioned, which are special because they do not roll back a running transaction, are no longer caught in the catch all. For more information, see the blog post X++, the catch.
Неожиданный поворот, починили
За это сообщение автора поблагодарили: Logger (1), AlGol (1), alex55 (3).
exception, mfp, occ, try/catch, x++, xpp, баг, исключения
mfp: What is new in X++ in AX7? Blog bot DAX Blogs 2 10.02.2016 00:29
Navigate Into Success: Try..Catch for .NET Interoperability Blog bot Dynamics CRM: Blogs 0 29.10.2014 09:00
Navigate Into Success: TRY.. CATCH in C/AL Blog bot Dynamics CRM: Blogs 0 17.10.2014 08:00
german_nav_developer: Catch Me If You Can – try-catch für .NET in C/AL Blog bot Dynamics CRM: Blogs 0 22.09.2014 11:00
ax-erp: Try Catch and transactions Blog bot DAX Blogs 0 29.10.2012 19:11
Часовой пояс GMT +3, время: 08:40.
