Старый 29.12.2006, 10:53   #5
mike1_imported is offline
mike1_imported
НА сайте MS Ответили следующее что это так и задумано )
Hi Mike1,
You are completely right! It is not possible to add AOT element as duplicate
to the project where such element is added. For example, if a user adds a
CustTable table to a Project, save and the attempts to add CustTable again,
system occurs 'Could not make a copy'. The same situation with elements which
have the same name, for example if user have CustTable table in CustTable
form, it is not possible.
This is by design. This was changed to have the same design as in 4.0, and
cannot be changed. Another group (sub-group) can be created in the project to
have the same element as a workaround.
Best regards,
Sergey
"Mike1" wrote:
> Hello, we installed KR3 (sp3) and saw 1 programmable problem!!! When we
> create any project and try to add table, form or report with the same name
> - AOT doesn’t allow it, it writes “COULD NOT MAKE COPY”. We can add objects
> with same name only using subgroups.
Оригинал ответа
http://www.microsoft.com/communities/newsg...11-948f731a24e3
Часовой пояс GMT +3, время: 00:28.
