Старый 06.04.2016, 18:11   #1
emeadaxsupport: Improved High Availability Support for SQL Clusters
Источник: https://blogs.msdn.microsoft.com/axs...-sql-clusters/
We have recently released an updated kernel for Microsoft Dynamics AX 2012 R3, KB 3141722, that will improve the way we handle the tables created in TempDB. As you may be aware, TempDB is a transient database, that means when SQL is started or after a cluster node failover, the TempDB database is created empty.... Read more
emeadaxsupport: AX Performance - What information and data to collect when you want to open a support case Blog bot DAX Blogs 0 29.09.2015 15:11
emeadaxsupport: AX Content: Cloud powered support Blog bot DAX Blogs 0 10.06.2014 00:14
emeadaxsupport: Microsoft Dynamics AX 2012 announced and discontinuation of support for Oracle Blog bot DAX Blogs 0 20.01.2011 17:11
Arijit Basu: Microsoft Dynamics AX High Availability Options Blog bot DAX Blogs 0 30.10.2007 17:10
Часовой пояс GMT +3, время: 02:40.
