Старый 07.11.2012, 17:11   #1
Malaysia: Storing last form values
Источник: http://axmas.blogspot.com/2012/11/st...rm-values.html
1. In the AOT, find the LedgerJournalTable form, and add the following code to the bottom of its class declaration:
AllOpenPosted showStatus;
NoYes showCurrentUser;
#define.CurrentVersion(1)
#localmacro.CurrentList
showStatus,
showCurrentUser
#endmacro
2. Create the following additional form methods:
public void initParmDefault()
showStatus = AllOpenPosted::Open;
showCurrentUser = true;
public container pack()
return [#CurrentVersion, #CurrentList];
public boolean unpack(container _packedClass)
int version = RunBase::getVersion(_packedClass);
switch (version)
case #CurrentVersion:
[version, #CurrentList] = _packedClass;
return true;
default:
return false;
return false;
public IdentifierName lastValueDesignName()
return element.args().menuItemName();
public IdentifierName lastValueElementName()
return this.name();
public UtilElementType lastValueType()
return UtilElementType::Form;
public UserId lastValueUserId()
return curUserId();
public DataAreaId lastValueDataAreaId()
return curext();
3. Add the following code to the form's run() method right before its super():
xSysLastValue::getLast(this);
AllOpenPostedField.selection(showStatus);
ShowUserCreatedOnly.value(showCurrentUser);
4. Add the following code to the bottom of the form's close() method:
showStatus = AllOpenPostedField.selection();
showCurrentUser = ShowUserCreatedOnly.value();
xSysLastValue::saveLast(this);
dynamicsaxtraining: Vendor returns Blog bot DAX Blogs 0 11.10.2012 00:11
dynamicsaxtraining: Paying a Vendor Blog bot DAX Blogs 0 22.03.2012 22:11
axhelper: Storing Last Form Values Blog bot DAX Blogs 1 25.10.2010 23:53
Часовой пояс GMT +3, время: 06:22.
