Старый 07.02.2012, 12:11   #1
axcoder: DEV_Toolbar: tabax for Ax2012
Источник: http://axcoder.blogspot.com/2012/02/...or-ax2012.html
I am sharing a tabax successor for Ax6 as an example of usage WPF control.
The form uses standard tab control from WPF with a custom template.
Also you can use it as an example of event handling.
The code has a problem which I can not resolve now: if you press a middle or right mouse button on a tab, vontr scrolls to the start - so you can accidentially close wrong tab. Now the workaround provided: if such event occured, event handler uses selected tab instead of tab under click
ax2012, tabax
Плагин к Tabax DEV_RegisterChange KingPeas DAX: Программирование 10 24.10.2011 05:35
axcoder: Tabax successor as an illustration of new dev features of Ax 2012 Blog bot DAX Blogs 0 01.07.2011 02:12
axcoder: AxPath pugin for Tabax which works with Ax3, Ax4, Ax2009 Blog bot DAX Blogs 0 08.11.2008 02:11
axcoder: Tabax is one year old Blog bot DAX Blogs 0 03.10.2007 17:10
axcoder: Tabax 0.3.2 Blog bot DAX Blogs 0 07.08.2007 21:10
Часовой пояс GMT +3, время: 23:01.
