Старый 17.06.2011, 16:02   #6
S.Kuskov is offline
S.Kuskov
3,449 / 1792 (66) ++++++++
Сообщение от Dark Smile Посмотреть сообщение
To copy the application directory is no solution because the size of it is more than 1 GB.
Copy can be only one layer, which is being developed...
But it is no solution too because then need to restart AOS.
Maybe try catch needed events on GUI in property panel?
axdaily: SQL temporary tables in AX 2012 Blog bot DAX Blogs 25 06.05.2011 10:18
sumitsaxfactor: AOSAuthorization property on tables Blog bot DAX Blogs 0 06.05.2011 02:19
Prabhats: DAX 2009: Temporary Tables in Enterprise Portal Blog bot DAX Blogs 0 27.04.2011 11:11
axhelper: How to Use Temporary tables in reports Blog bot DAX Blogs 0 29.09.2010 18:05
Microsoft Dynamics AX AIF: Sending Outbound Documents Automatically Blog bot DAX Blogs 0 31.03.2008 11:05
Часовой пояс GMT +3, время: 14:06.
