#27 |
Ну вот, то, о чем говорили менее полутора лет назад как о теории и экспериментальных изысканиях, стало реальностью
![]() Цитата:
Сообщение от Blog bot
![]() Источник: http://blogs.msdn.com/b/mfp/archive/...-language.aspx
In Dynamics AX 2012 we are compiling X++ code to the CLR. At compile time we generate an XML representation of the pcode, which we can convert into IL. At run-time we will be executing the IL for batch jobs, service calls and RunAs constructs. (RunAs is a new method allowing you to request the X++ logic to be executed as IL.). Peter demonstrated how the performance characteristics are vastly different particular in situations with extremely many objects or extremely many methods calls. |
За это сообщение автора поблагодарили: mazzy (2). |
Теги |
.net, c#, x++, что нового, перспективы |
Тема | Ответов | |||
DeniZone: Copy - paste utility | 0 | |||
DeniZone: x++ and C# compared | 0 | |||
DeniZone: Opening a form on start up of AX | 1 | |||
Dynamics AX: The Future of Dynamics AX and Web 2.0 | 0 |
