Старый 23.11.2010, 15:11   #1
Dynamics Ax: Development Tips on Application Integration Framework
Источник: http://axblog4u.wordpress.com/2010/1...ion-framework/
Is there any way to turn off the mandatory fields when working on AIF? All the table fields for which the mandatory field is said to “Yes” are by default enabled in AIF data-policies form. To make this field as not mandatory on Ax Table classes. In AxBc’s please override the method initMandatoryFieldsExemptionList () if [...]
axbc
Microsoft Dynamics AX 2009 White Paper: Application Integration Framework (AIF) BizTalk Adapter Configuration for Data Exchange, Part II - English Vadik DAX: База знаний и проекты 0 14.04.2009 09:36
Dynamics AX: Dynamics AX 4.0 - Application Integration Framework - Overview Blog bot DAX Blogs 0 28.10.2006 16:40
Часовой пояс GMT +3, время: 10:04.
