Старый 15.11.2009, 21:05   #1
Arijit Basu: AX Application Launcher v2.1
Источник: http://daxguy.blogspot.com/2009/11/a...ncher-v21.html
I received some quick feedback on the UI color ;-P. I have changed the UI color to something that will hopefully be pleasant to the eyes :-). [Lemme see if I can create something like a theme...]. The new UI is as:
The installer files are attached below:
Thanks for the feedback :-)
Arijit Basu: AX Application Launcher v2 Blog bot DAX Blogs 0 14.11.2009 22:05
Arijit Basu: AX Application Launcher Blog bot DAX Blogs 0 21.02.2009 19:06
Arijit Basu: AX 2009 Document Management & MOSS / WSS Blog bot DAX Blogs 0 23.01.2009 01:07
Arijit Basu: Reporting & BI in AX: An Overview [Level 100] Blog bot DAX Blogs 0 07.01.2008 16:01
Часовой пояс GMT +3, время: 20:47.
