#13 |
Чайный пьяница
Сообщение от vital.mih
using System;
using System.Collections.Generic; using System.Text; using System.Data.Sql; using Microsoft.SqlServer.Server; using DiasToCrm.CrmWebService; namespace DiasToCrm { public static class Proxy { [SqlProcedure()] public static void AddCustomerToCrm(string ExtID, string Name, string INN, int RelationshipType, string Phone1, string Phone2, string Phone3, string email, out string Test, out string ErrorMessage, out string Ret_Error) { Test = String.Empty; ErrorMessage = String.Empty; // по дефолту ошибок нет Ret_Error=String.Empty; try { // Set up the CRM Service. CrmAuthenticationToken token = new CrmAuthenticationToken(); token.AuthenticationType = 0; token.OrganizationName = "ServiceDesk"; CrmService service = new CrmService(); service.Url = "http://crm:5555/ServiceDesk/mscrmservices/2007/crmservice.asmx"; service.CrmAuthenticationTokenValue = token; service.Credentials = System.Net.CredentialCache.DefaultCredentials; QueryByAttribute query = new QueryByAttribute(); query.ColumnSet = new AllColumns(); ; query.EntityName = EntityName.account.ToString(); query.Attributes = new string[] { "new_ExtID" }; query.Values = new string[] { "111" }; RetrieveMultipleRequest request = new RetrieveMultipleRequest(); request.Query = query; request.ReturnDynamicEntities = true; //Выводим коллекцию значений try { RetrieveMultipleResponse response = (RetrieveMultipleResponse)service.Execute(request); BusinessEntityCollection Customer = response.BusinessEntityCollection; Test = Customer.BusinessEntities.Length.ToString(); } catch (Exception Ret_ex) { Ret_Error = Ret_ex.Message; } } catch (Exception ex) { ErrorMessage = ex.Message; } } } } Я максимально упростил процедуру и создал аккаунт с атрибутом new_ExtID=111. service.Url = "http://crm:5555/ServiceDesk/mscrmservices/2007/crmservice.asmx"; на service.Url = "http://crm:5555/mscrmservices/2007/crmservice.asmx";
Эмо разработчик, сначала пишу код, потом плачу над его несовершенством. Подписывайтесь на мой блог, twitter и YouTube канал. Пользуйтесь моим Ultimate Workflow Toolkit |
| Теги |
| c#, webservice |
| Тема | Ответов | |||
| RetrieveMultiple и сущности НЕдефаултной организации | 16 | |||
| Быстродействие CrmService | 16 | |||
